AVR-2105 question about Prog Scan
Discussion in 'AV Receivers & Amplifiers' started by monkeyspank, May 23, 2005.
  1. monkeyspank
    monkeyspank
    Feb 17, 2005
    157
    I am in the market for a new A/V amp to go into the spare room cinema that I am still drawing up.
    I am going to have 2 or 3 sources which will be operating in progressive scan. I would like to use the A/V amp as a switch for these so that I can connect the amp to the projector and not have to keep swapping cables around.
    I just wanted to check that the amp can handle progressive scan. It's not something that is documented and I can't find the info anywhere. I would be gutted if I came to put everything together and be dissappointed because I didn't check.
    Any help gratefully appreciated, as always :)
  2. Jase
    Jase
    Mar 16, 2001
    9,462
    South Coast
    +890
    Yes. It will pass thru a Progressive Scan signal. :)
  3. monkeyspank
    monkeyspank
    Feb 17, 2005
    157
    Beauty :thumbsup:
    Thank you dude, that has decided it.
  4. Spooksta
    Spooksta
    Nov 7, 2000
    2,679
    Planet Earth
    +304
    Ive got this amp any when i run a Laser disc Composit through it to my projector im getting crap at the bottom of the screen outside the widescreen picture area. This does not show on my tv just the pj. Any ideas. Supose i must check the signal on it own with out going through the amp..
