AVR-2105 and component
Discussion in 'AV Receivers & Amplifiers' started by marky1975, Aug 14, 2005.
  1. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    Hello
    Could some one help me Pleaseeeeee!!!!
    i have sky+ and dvd which are composite , panasonic plasma which is RGB/component and the 2105.
    im trying to get conponent out my plasma is component.
    i have pluged the R,G,B leads in to component. mointor out on 2105.
    but noting happends.
    am i right in saying that you have to have component dvd,sky etc IN to have component coming OUT.
    cant the 2105 convert composite IN to component OUT?
    or do i have to change a setting on the 2105?(which i have looked for but cant find anything for it).
    all help greatly recived
    if cant it has to have component IN can i use scart to component lead
    MArk rider
  2. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    The UK/Euro version of the 2105 doesn't have Video Upconversion. It will only switch the signal e.g S-Video IN - S-Video OUT, Component IN - Component OUT.
    You'll either need an external RGB or S-Video to Component Convertor or just plug directly into the Plasma for all your sources. You should be able to get extra Input Boards for the Plasma that accept S-Video etc.
  3. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    Thanks Jase
    i thought that might be the case will have to invested in component dvd.
    does anyone know if you can get a componet sky+ box
    thank you
    Mark
  4. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    also jase when you plug componet IN and plug plasma to Component monitor OUT does it auto select the output to the Component or do i have to change settings on recevier as i have composite mointor OUT to my plasma tunner box
    MArk
  5. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    There are no Sky+ boxes with Component Outs. Sky's new HD box should have them when they start broadcasting in HiDef.
    You'll need to assign the Component Inputs to the correct Input e.g DVD. This is done from the Setup Menu. Once done, you then just select the DVD Input and the video will be passed through.
    As it stands. What inputs does your Plasma have?
  6. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    have got RGB/component inputs on plasma.
    Mark
  7. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    Does it have an S-Video input as well?
  8. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    no only rgb
  9. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    Have you considered adding a Scaler/Video Processor at all? Just a thought.
  10. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    whats that?
    im think of getting a converter box for scart to component. that will be easyest plug straight in to amp as my dvd is plugged into amp
  11. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    A Scaler/Video Processor will scale the incoming signal to a higher resolution as well as converting signals from one format to another e.g S-Video to Component, Component to RGBHV etc.
    Some older models can be picked up for not much more than you'd pay for a new convertor box. An older Lumagen Vision for example has one Composite Input, an S-Video Input and a Component Video Input. The output is via VGA which then connects to either your plasma's PC input or the Component Inputs (depending on which cable you purchase). Have a look here:-
    http://shop.store.yahoo.com/hometheaterplus/luvivipr.html
    Certainly worth thinking about. :)
  12. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    exelent thanks very much for your help Jase
    Mark
