D dp600 Guest Aug 7, 2006 #1 The wordsPL 11C are showing on the amp when I am playing a DVD is this an error mess and if so what dos it mean.Thank You.
Ultra2man Prominent Member Joined Dec 19, 2003 Messages 1,510 Reaction score 479 Points 322 Location Biggleswade, Bedfordshire Aug 7, 2006 #2 Sounds like 'ProLogic 11 Cinema'. Have you selected the DD 5.1 sound track on the DVD or have you only connected it with analogue stereo phono cables ?
D dp600 Guest Aug 7, 2006 #3 Thank you it might have been the pro logic as i know it is connected ok.I admit i forgot to select the soundtrack.
Ultra2man Prominent Member Joined Dec 19, 2003 Messages 1,510 Reaction score 479 Points 322 Location Biggleswade, Bedfordshire Aug 7, 2006 #4 No problem. The default soundtrack, especially on older discs, is not always the DD 5.1 soundtrack so you have to check sometimes.
