J
Jack Dotson
I recently purchased a Outlaw Model 7500 and am having issues with the remote trigger feature. It turns off and on just fine, problem is it also turns off then back on each time I select a different input.
It doesn't happen every single time, but most times.
The manual refers to the remote trigger as a "stereo" input. I've always used the mono type plug for this purpose and this is the same wire I used with my old Outlaw Model-755 and never had an issue.
Anyone else experience this sort of problem?
