AVP-700 DAC question?
Discussion in 'Arcam Owners' Forum' started by Crawdaddy, Aug 11, 2005.
Tags:
  1. Crawdaddy
    Crawdaddy
    Hello,
    (first post, glad to find this site!)
    I have a DV78 player connected to a Rotel RSP-1066. I use the DV78 for both CD (analogue connection) and DVD (digital connection) with what I consider good results. However I'm excited to look at the new AVP-700, which I believe has 24bit - 192kHz DAC's. True?
    If I connect my DV78 to the AVP-700 via digital out and let the AVP do the processing, will I get audio performance on par with the CD192? What kinds of improvement should I expect?
    Thanks in advance!
    Crawdaddy
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    I'm not sure exactly what DACs it uses, but if it does use Wolfson 24/192 upsampling DACs then I am sure it does not use 4 per channel in dual differential mode as the CD192 does. If you want CD192 performance then buy a CD192.
  3. cpd
    cpd
    Aug 7, 2005
    35
    Does anyone know the details of the DACs in the AVP-700? I know that they are Wolfson, but that's about it.
    Chris
