Avoiding system damage
Discussion in 'AV Receivers & Amplifiers' started by Ivo Simons, Feb 27, 2003.
  1. Ivo Simons
    Ivo Simons
    Hello everybody.
    I just bought a kenwood KRFX-9060D receiver and a JBL SCS-178 set of speakers.
    Everything works fine and it sounds great , but ...
    On the receiver, I may only attach speakers with an impedance between 6 and 16 Ohm.
    The speakers are only 4 Ohm.
    Can this damage my system, or will the Kenwood receiver automatically switch to a lower level?
    Thanks for the replies
    Ivo Simons (Belgium)
  2. cribeiro
    cribeiro
    Nov 2, 2002
    2,809
    A Spaniard in Germany
    +308
    It is not a good idea. I do not know the principles, but I think you may damage your amp...d
  3. EvilMudge
    EvilMudge
    The amp will clip at a lower volume level if you run it with lower impedance speakers than it is designed for. As ever, if you're sensible you'll be fine, but a moment of madness could end in tears. Don't turn it up beyond the point where it starts to distort and everything will be okay - except that the amp may get rather hot.:devil:
  4. cribeiro
    cribeiro
    Nov 2, 2002
    2,809
    +308
    Ok, then it is what I expected, but I was not sure. thanks, because now I know a little bit more.
