avnutter,s home cinema progress...
Discussion in 'Home Cinema Building DIY' started by avnutter, May 26, 2005.
  1. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
  2. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    Thats coming on well, definitely keep us posted with updates.
    Do you have two garages?
  3. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    yes i have two garages, there is a door going into the second garage and also one into the main house. by the way inzamam i was influenced by your project and i will be having brown suede too. thanks. will add more photo,s soon
  4. martian1
    martian1
    Dec 30, 2001
    2,227
    63
    Sunderland
    +241
    I have had a tester to try of the suade paint, i will be using this as well perfect for a HC room. :smashin:
  5. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    Thanks :blush:
    Thats what the forums are for.
    The brown suede is excellent for home cinema imo, not only does it look very classy it is also very light absorbant.
  6. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    Livingston, Scotland
    +225
    Keep us posted AVNutter :thumbsup:
  7. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
  8. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    It looks excellent, especially the way it now looks like an original room.
    I bet you cannot wait until its complete.
  9. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    Nice one... I also want to convert my garage into a "normal" room later (behind my lounge/HC).
    What do you guys do for heating in there?
  10. BestGear
    BestGear
    Oct 22, 2003
    1,158
    +30
    ...that looks like a veritas excel alarm and rkp.... you can remove the rkp if you want - help tidy that up ....
    I assume obviously that you have another rkp elsewhere!
    DJ
  11. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    the alarm system will get boxed in with a little door for access. that is a veritas excel with a phone dialer, so it rings my phone if it went off.
    the decorator is in at the momment, will take more shots soon.
    had my 203 cm saphire remote electric screen deliverd today and its heavy, does anyone have any ideas as to how to mount it on the ceiling because there only seems to be plasterboard?
  12. BestGear
    BestGear
    Oct 22, 2003
    1,158
    +30
    Hi...
    There must be straps holding to which the platerboard is screwed... or depending on construction, straight onto the joists for the floor above.
    You could get a length of wood cut, fix it to the ceiling joists above, then screw the screen to the newly fixed wood....
    DJ
  13. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    nice one, i thought that might be the case..
  14. BestGear
    BestGear
    Oct 22, 2003
    1,158
    +30
    AVNutter - have you played with your Excel?
    It has 8 (from memory) aux outputs and is programmable from a PC..... there is a serial connector inside on the PCB and you can get a small interface from texecom for not much money!
    D
  15. BestGear
    BestGear
    Oct 22, 2003
    1,158
    +30
    AVNutter ....if you PM me your email address I can send you something of interest....
    D
  16. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    a qustion for inzaman......
    my decorator has just been today and he did the first coat of the suede paint with a roller. i was at work at the time and i,ve just got back and it does not look too good. i asume he will do the second coat with a brush with random movements. am i right or should i be worried? and if that is the case will it come out ok with a secon coat using a brush? thanks in advance.
  17. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
  18. johndon
    johndon
    Feb 3, 2002
    1,924
    48
    +88
    We tried the chocolate suede colour a few weeks ago and it did look terrible after the first coat - the look improved considerably after the second.
    John
  19. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    Apologies, i was away most of June.
    Did this come out okay after the second coat.
  20. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    the pictures you see in stage three are with the second coat and its come out fine, just the coving to do now and some fitted furniture to house the av equipment and projector.
  21. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
  22. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    That link is showing this message;
    This space is temporarily unavailable. Please try again later.
  23. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    seems to working now....
  24. rooo
    rooo
    Oct 12, 2004
    266
    +5
    All looking good. A side issue but your house looks better from the outside too with only one garage, it seems to look more balanced.
    Looking forward to the next stage pics!
  25. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    stage 5 now complete. joiner has fitted the cupboards to house the av stuff.
    undercoat has also been applied.
    i,ve managed to host the pdoto,s on photobucket which look better.
    stage 1
    http://photobucket.com/albums/d117/avnutter/
    stage 2
    http://photobucket.com/albums/d117/avnutter/stage 2/
    stage 3
    http://photobucket.com/albums/d117/avnutter/stage 2/stage 3/
    stage 4
    http://photobucket.com/albums/d117/avnutter/stage 2/stage 3/stage 4/
    stage 5
  26. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    stage 1
    stage 2
    stage 3
    http://photobucket.com/albums/d117/a...202/stage 3/
    stage 4
    http://photobucket.com/albums/d117/a...203/stage 4/
    stage 5
  27. johndon
    johndon
    Feb 3, 2002
    1,924
    48
    +88
    Only the first link seems to work :(
    John
  28. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
  29. ash
    ash
    Jun 9, 2005
    11,036
    +383
    What paint is that you used?
  30. avnutter
    avnutter
    Feb 7, 2005
    1,541
    west yorkshire
    +185
    the paint is brown suede effect from b&q.
    the same as what inzaman has used.
