AVIC-X1R Problem Please Help!!!!!!
Discussion in 'Video Streaming Boxes & Services' started by J4KO, May 10, 2005.
  1. J4KO
    J4KO
    Hi all,
    I recently purchaced and installed (by a profesional fitter) my pioneer avic-x1r every thing works fine apart from the voice on the guidence i cant hear it at all the radio mutes but no voice is there i was wondering if any one else has had the same problem and knows how to cure it ive read the intruction book but i am still none the wiser i cant get hold of the fitter he is out of the country for two weeks please can some one help cheers :thumbsup:
  2. Rubble
    Rubble
    Dec 8, 2003
    2,265
    Suffolk
    +35
    just a thought if you press the blue menu button, under the settings tab, select hardware volume there should be 2 settings one is guidance volume mine was default at zero.
  3. J4KO
    J4KO
    all volume is up voice and beep voice guidance is switched on but as i said the radio mutes when you get near a turn you have to make but i cant hear a beep or a voice..................
  4. eggie99
    eggie99
    Nov 11, 2005
    24
    hi
    i'm having a similar problem i get no guidance volume and no est time of arrival also no mixed mode and street list display in navigation mode but if i switch to demo mode evrything is fine.
    i also askin for help please.
    Have reset the unit and still the same also i have not installed speed pulse but that doesnt affect the system performance anyway.
    thanks
    Eggie
