Avia vs. Video Essentials
Discussion in 'Televisions' started by xprezz, Jun 3, 2005.
  1. xprezz
    xprezz
    I need to calibrate my sony CRT tv. looks a bit off and tilts on one side and bends outwards on the other (sorry dont know the technical terms for this). Which dvd out there would be the best to calibrate my picture, not just color and sharpness, also the actual picture (straight lines etc).
  2. MikeD
    MikeD
    Mar 17, 2001
    265
    Paignton, Devon, UK
    I've got a feeling that of the two you mention only DVE supports PAL, anyone know different?
  3. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    True. I have avia, it is only NTSC. Also good for 5.1 sound.
    However, if you have a dvd player that can turn a ntsc signal to pal, you will be ok with avia.
