AViA PRO
Discussion in 'Movie Forum' started by Chaos Star, Dec 4, 2003.
  1. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Enough Calibration to cause a marital split :)
    Heres a little Information for anyone how likes tune up there kit:
    "Avia Professional (Avia PRO) is a multi-disc test suite developed by Ovation Multimedia
    designed to be an all-inclusive product for the calibration of home theater systems. The
    suite consists of five DVDs, a CD, plus a user manual. Avia PRO is the most technologically
    advanced product for use in the professional and home theater environments.
    Avia PRO offers users a rare combination of industry standards and state-of-the-art test patterns
    to achieve superior sound and video quality.
    Ovation Multimedia developed more than 1,000 new test signals, with approximately 3,000
    variations, and over 100 sound tones as part of the Avia PRO product. The series of discs also
    includes Faroudja-Genesis Microchip test patterns, Consumer Electronic Association (CEA)
    DVD Video Test Disc, SMPTE test patterns, and Room Optimizer and Room Sizer Software
    from RPG. The printed manual provides necessary instructions for the use of each disc.
    Avia PRO not only improves “traditional” signals, but also permits functions never before possible.
    The variations of available patterns allow users to select the one best suited for the job, resulting
    in a customized test pattern generator for each project.
    As changes in technology occur, updates to Avia PRO will be available in a timely manner. With
    its 3-ring binder format, the library of discs can expand by simply adding DVD carrier sleeves,
    while the manual design allows for text pages to be added or removed as necessary."
    I have more indepth information on the product but dont want to bore you all to tears :)
  2. Family Guy
    Family Guy
    :boring: Uh....sorry mate...what was that...
    :D
    Must be quite hard trying to calibrate those cardboard boxes since your move, eh Piero?:devil:
  3. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    :rotfl: Ah very good - if all goes to plan I should be unpacking the boxes in the near future, just in time for the release of Avia Professional :)
    And anymore wise crackes and I will be posting a much big spec for the Calibration suite that would make your eyes water :)
  4. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I'd like to be able to rent a copy of Avia Pro...
    *edit* and does it include PAL versions of each pattern?
  5. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    No PAL Patterns Im afraid.
    Im hoping that one of the extra discs that will be available in the future will have PAL Patterns.
    Renting would that not be Illegal ?
  6. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Dunno.. I understand the primary market for this is professional calibrators. Legally, what would be the difference between somone coming round your house with a copy and renting it yourself? I think you'd have to check the licence that comes with it.
  7. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Could be right, have to say Im not sure just sounded a little dodgy to me.
