avia or dve?
Discussion in 'Projectors, Screens & Video Processors' started by mr ooops, Jan 1, 2005.
  1. mr ooops
    mr ooops
    Mar 4, 2003
    3,592
    103
    Hardwicke and Wotton
    +353
    Hi all,
    bout time i set my z2 up properly which would you guys recommend to help set it up avia or the DVE disc?
    many thanks
    Jason
  2. paul1672
    paul1672
    Jul 31, 2003
    2,552
    71
    norfolk
    +36
    depends if your playing ntsc or pal dvd's????
    for ntsc you could use avia or an ntsc version of dve.
    for pal it will be a pal version of dve.
    avia is only available for ntsc.
    hope that helps
    paul1672
  3. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    I've got both but if I had to pick one it would be Avia, much easier to use for basic calibration and much easier to navigate.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,128
    I far prefer Avia but it doesn't have any video levels outside 16-235 so no below black pluge. Apart from that its nice and easy to use.
    DVE does have the full range on the disc 1-255 (or at least range outside 16-235) so you get a below black pluge and the grayscale ramps are useful for setting contrast ( 16 and 235 indicators).
    I actually still use the original Video Essentials more often than not .
    The PAL/NTSC flavour is a bit of a non-issue to be honest.
  5. pierrev
    pierrev
    Jul 7, 2004
    I am thinking of renting a copy of DVE but how easy it is to use ?
    do the instructions of what to do come on the disk, or on a separate pamphlet (which is unlikely to come with the rented copy) ?
    cheers
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I find navigating DVE a nightmare, how anyone could put together something so impenetrable is beyond me .. with Avia the basic calibration tests are just two menu selections away.
  7. moco
    moco
    The DVE disc is quite easy to navigate if you use the hardcopy table of contents supplied with it - you just choose title and chapter.
  8. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    1,325
    LONDON
    +241
    Never used Avia, but DVE can be a bit Esoteric for a newbie! :)
