Avia DVD Special glasses
Discussion in 'Plasma TVs Forum' started by Leerock, Mar 9, 2005.
  1. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    I ve heard that if you buy avia or dve discs you ll need some glasses :cool: with color filters or sth in order to make adjustments using all the test patterns.
    Is it true or is this just another stupid question?
    I was about to order the dve disc but this is what pulls me off.
    If it s true where can I find these filter glasses?
  2. mike543
    mike543
    Jan 2, 2005
    221
    +3
    hi,
    you get a card with three colour filters(red,green,blue) included with dve. you just hold it in front of your eyes to adjust.
  3. stevelup
    stevelup
    Aug 13, 2002
    6,833
    Swindon
    +1,310
    The filters come complete with the Avia DVD as well.
    It's worth pointing out that they are only used for setting colour saturation and hue so if you're inputing RGB via the VGA socket you are not going to need them anyway.
    Steve
  4. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    Avia DVD is NTSC only right?
  5. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Yep, and DVE comes in both PAL & NTSC flavours.
    S.
  6. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    Ok that was what i thought, so AVIA is pretty useless in PAL territory if you aren't calibrating for NTSC.....
  7. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    I wouldn't say it was totally useless, still better than nothing but I'm guessing that an optimised PAL calibration disc such as DVE would be better. Maybe Gordon, Liam etc. would have a view.
    S.
  8. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    thanks guys
    I m going to order dve then
