Avia DVD recommends Optical over Coaxial
Discussion in 'AV Receivers & Amplifiers' started by KraGorn, Dec 9, 2003.
  1. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Although I've had the Avia calibration DVD for some time I've never watched it through before .. when it came to the section on interconnects they said that in preference one should use and optical digital connection as opposed to coaxial because coax can introduce noise and hum.
    Given that the entire DVD is aimed at helping one achieve maximum audio and video quality it surprised me they decided that noise injection was a more serious problem than a DA->AD conversion cycle.
    Is this a strange recommendation? :confused:
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    No it makes much sense :)
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    But the 'conventional wisdom' round here seems to be coax in preference to optical due to the DA/AD step.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Make sure you use the right sort of Coax cable. ;) Have a look in the PowerBuys Forum at Mark Grant's cables.
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Granted I am the biggest fan of what Mark and others are doing commercially (see my new mega post on this tonight) but optical systems when implemented correctly can offer some advantages, the problems is we don't often give them the credit when it is due. everyone is obsessed with coax here but if you need to isolate say ground optical is your answer. Personally I generally use coax but have optical for HCPCs perhaps going to a reclocking box because of the 'advantages'. It is not as black and white as many make out. Good optical are £40, BEST coax is nearer £20! So I guess this explains much!
  6. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    I would certainly add from a user perspective that recently i compared a Belden/Canare co-ax against a Van Den Hul optocoupler mk2 and another U.S sourced glass fiber optical link and in complete honesty and slight surprise i prefered the two optical's. That said it required a 2.00am listening session and the "differences" were slight at best.
    Regards
    Steven
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    it is also worth bearing in mind that optical is simply more common over there...... that goes a long way towards alot of things......
    ad
  8. NicolasB
    NicolasB
    Oct 3, 2002
    6,438
    Emily's Shop
    +887
    This is never going to be a clearcut question. Different pieces of equipment may well have better or poorer optical implementations compared to the coax implementation on the same piece of equipment. My Arcam DV27, for example, is limited to 48 kHz on the optical output, but can produce 96 kHz at the coax output. At present the practical significance of that is isn't very great, but I live in hope.... :)
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    The DV27 can output 96 through its coax output but doesn´t due to copy protection laws... :suicide:
    A friend had an exchange of e-mails with Robert Watts, the designer of the Chord DAC64, and DPA before, and he said optical is better, but some friends tested and always preferred coax... :rolleyes:
    In the end, apparently optical more imune to RF, but worst regarding jitter, and the DAC64 is supposed to eliminate jitter, but testing didn´t confirm it... :thumbsdow
