aVIA CALIBRATION
Discussion in 'Home Cinema Buying & Building' started by (GTV)Chris, Apr 26, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    hI
    I am nearing moving to my new house..thank the Lord.
    There will be a dedicated cinema room.
    I have bought Avia for my HCPC and was wondering if I should buy a sound db device for measuring the speaker levels.
    ARe the digital ones better than the analogue ones?
    Ta
    C
  2. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    The analogue ones are usually recommended. Get one for £25 here
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Unless you have Superman ears then a sound meter is a great investment.
    Better to have a well set up cheaper system than badly setup more expensive equipment.;)
  4. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    thanks for the info on the meter...]
    And very well said John, you are absolutely right.
    Ta
    C
  5. Kramer
    Kramer
    Nothing to do with HCPC'ing so..
    moved to speakers.....
