avi to dvd
Discussion in 'Blu-ray & DVD Players & Recorders' started by markxb, Sep 15, 2005.
  1. markxb
    markxb
    I am using pinnacle studio 9se for capturing/editing footage from my camcorder and i am saving the finished footage to my hard drive by creating an avi file, i would like to now burn these home videos to dvd and need help and guidance on how to do this and what software to use.
  2. jinkyjim
    jinkyjim
    Feb 23, 2005
    252
    County Durham
    +9
    WINAVI is the best prog to use, you just load your avi file in winavi, press convert then about 30mins later its ready to burn on to a blank DVD.
    jim
  3. av2diefor
    av2diefor
    Nero6 will also handle it, if you have a divx player(so cheap now) you can burn the avi and play it.
  4. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    If you're planning to burn your avi to dvd just copy as a data disc.It will play on a dvd player if it plays avi files.that is it will play.Divx and Xvid files.I have found when I play my avi files this way the player sometimes freezes or I have had lipsink issues.So I copy all my homemade films using Pinnacle studio 9 onto dvd as a normal dvd with chapters so you can break the film up into smaller segments.So I can goto my fav bits quicker.You will also be able to play your films around your family and friend houses as it will be unlikely the will have the correct dvd player for AVI files.
  5. laser
    laser
    Aug 1, 2004
    986
    Hartlepool
    +45
    I don't know if your version of Studio 9 is a cut down version but you can capture, edit, and burn to DVD with chapters and menus all within Studio 9 using the three tabs in the studio 9 software, Capture, Edit and Movie.
    The process is pretty straight forward and the resulting DVD's are pretty good with regards to the PQ.
    One problem I found when using some third party software applications to generate a DVD from an AVI file is the sound and picture are sometimes slightly out of synch by a few frames.
  6. markxb
    markxb
    Big thanks to you all.
    Will post again if i have any trouble,
    Watch this space !!! :hiya:
  7. marty2005
    marty2005
    Jul 22, 2005
    3,699
    Great Yarmouth
    +155
    I use DivXtoDVD
    Creates Vob files from an avi file.
