.AVI through windows media center to 360
Discussion in 'Xbox Forums' started by OmniFox, Jan 20, 2008.
  1. OmniFox
    OmniFox
    Dec 13, 2006
    183
    Maine, USA
    +12
    As the title says, i want to be able to download movies from the net (which generally give me a .avi file extension) and run them from my pc, to my 360 so i can watch them on my tv.
    I'm able to locate them in WMC on my 360, but can;t play them cause it says im either missing a codec or the file is corrupt (which isn't the case).
    Is this possible?
  2. RTF
    RTF
    Transcode360
  3. OmniFox
    OmniFox
    Dec 13, 2006
    183
    Maine, USA
    +12
    what is that exactly?
  4. prettyvacant
    prettyvacant
    May 22, 2006
    363
    Wolverhampton
    +55
    DivX/Xvid can only be played directly from the 360 dash at present, they aren't supported through the Media Centre extender :(
    It's annoying but we might get an update in future to correct this...
    Hope this helps
  5. Democritus Mav
    Democritus Mav
    Dec 11, 2006
    678
    46
    I'm in your base stealing your Flag!
    +188
    Try this Link
    As the page says some free software that converts .AVI files to files the 360 can use.
  6. Tw1sted Demon
    Tw1sted Demon
    Aug 14, 2007
    46
    +5
  7. scor81
    scor81
    Dec 14, 2006
    214
    +10
    good links, thanks
  8. bubs999
    bubs999
    Apr 8, 2007
    3,181
    Hampshire
    +631
    Just use the media blade and select Videos. This will save you having to do any converting, as the 360 now plays Divx files.
  9. RTF
    RTF
    Just google transcode360 and use that to be able to play divx files in wmc.
  10. doublej
    doublej
    Jul 3, 2005
    122
    +13
    Don't use Media Centre,. use Windows Media Player. DivX is only support by WMP Sharing - not Media Centre Extenders.
    Rubbish, but true.
  11. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
