AVI Files problem on a Philips 720SA........
Discussion in 'Blu-ray & DVD Players & Recorders' started by Towner, Aug 9, 2005.
  1. Towner
    Towner
    Aug 31, 2004
    639
    +58
    Just got a Philips 720SA and am having problems playing AVI files. The 720SA recognises them as AVI files from the DVDR (displays AVI folder) but when I go to play them it will only play the sound and not display a picture!!!! The backdrop stays the same as if I had just turned it on. Any ideas much appreciated. Thank you.
  2. ermintrude
    ermintrude
    Jul 13, 2004
    AVI files can have the video/sound encoded in many formats.
    For an AVI to play sucessfully both video and sound must be encoded with codecs that the pghips can decode. E.g mpeg2, DivX4 etc
  3. Towner
    Towner
    Aug 31, 2004
    639
    +58
    Being rather new to this, is it when your burn the files to disc (with NERO) that they are burnt either as a MPEG2 or DIVX4 file???
    If not, how or what do I use to convert them to the correct files??
    Thank you Ermintude.
  4. ufitsy
    ufitsy
    Aug 18, 2004
    3,237
    103
    Midlands
    +341
    the way I understand it .AVI means that it is just a container - it could be one of many formats (divx 3/4/5, xvid ect). Download a decent divx player and it should tell you the codec/format of the file you are playing. I may be wrong but I think that mpeg2 is vcd format.
