Big_Si_Owen
Established Member
sexytom said:Quick question, when you use the line input on one Sonos device, does it let you play that input on all the zone devices?
Yep, sure does!
Yep, sure does!
Can any of you knowledgeable folks recommend me a solution that might fit the bill?
Just to get it straight in my own head, am I right in thinking that:
Multi-room = ability to play from ONE source to different rooms, selectively.
Multi-zone = abillity to play from multiple sources to multiple rooms?
Hope you can help with this and I will certainly keep you all updated with pics
So with AE you can only listen to same song in each room, no way to change song from room to room?
I don't mind spending around £200 on hardware if that makes a nice simple solution.
multi room amplifier with DLNA
