AVF GC Help me fix my pressure washer
Discussion in 'General Chat' started by DVD-Man, Jun 12, 2015.
  1. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    Hi folks,
    I don't know what I am supposed to search for here so looking for help.
    My pressure washer works but the issues are:-
    The lance comes in 2 parts and when you assemble the lance the water comes out of the join.
    The soap bottle won't stay on the lance (thread?)
    I'm not too fussed about the bottle, what would fix the leak?
  2. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,241
    As a quick bodge try tightly wrapping the join in (lots of) PTFE tape, then wrap again with electrical tape to give it some strength and give it a go, see what you get?
    The PTFE will probably work for the thread on the soap bottle too. Just 1 or 2 layers around the male thread should help..
    If the PTFE helps but doesn't cure the leak, have another go but this time add some Instant Gasket into the equation. ;)
  3. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,479
    East Riding of Yorkshire
    +5,726
    Is there an O ring missing around the male part of the lance? Similar to the black ring at the base of this picture.
    [​IMG]
  4. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    That might be it, there isn't the same resistance when joining the two halves of the lance.
    How would I measure and buy such a thing?
  5. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    This would be better with pics too I suppose but at the moment I am getting my outside tap fixed.
  6. SteveCritten
    SteveCritten
    Aug 13, 2009
    11,053
    Caistor Lincs
    +4,820
    I am sure if you go on the manufacturers website they will have a parts list for every model. It's a common thing for the o ring to go so will be readily available at all good retailers ;)
  7. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,479
    +5,726
    I think you can buy a mixed pack of various sizes on amazon. I'd just buy that for a few quid and then trial and error. Or go to B&q and liberate one of the hoselock display. I wouldn't. But I might.
  8. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    It's one of these unbranded affairs, perfectly adequate for me given my dad gave it to me.
    I've actually got these for the tap to pressure washer bit, the good ones and the poop.
  9. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,479
    +5,726
    Try an o ring from off the sh*t one then.
