AVF font size
Discussion in 'General Chat' started by 2010, May 4, 2007.
  1. 2010
    2010
    Oct 1, 2005
    942
    W4
    +52
    Is anybody else having trouble with the forums text size today?
    It is far larger then normal & I have had to use Ctrl - to reduce it in Firefox but it still doesn't look right :confused:
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    In Internet explorer nothing has changed.
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,293
    2
    137
    Airdrie, Scotland
    +1,079
    I use Firefox and nothing has changed.
    Cheers,
    Martin.
  4. C225
    C225
    May 15, 2006
    6,290
    Linlithgow
    +785
    Firefox and safari are fine for me on my mac.
  5. Digger
    Digger
    Dec 31, 2003
    4,397
    World Wide Supermarket
    +206
    Have you accidentally scrolled the mousewheel up whilst pressing Control key?
  6. 2010
    2010
    Oct 1, 2005
    942
    W4
    +52
    No, I'm not sure what's happened tbh!
    If I press Ctrl & 0 (which should return the page to its 'normal' resolution) everything is too large :rolleyes:
  7. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    Try this...
    Go to the forums home page, scroll down to the bottom and on the left you will find a drop down list which allows you to select the text size.
    EDIT: Just noticed that the list is at the bottom of every page.
  8. 2010
    2010
    Oct 1, 2005
    942
    W4
    +52
    Thanks, that was indeed the problem although I'm not sure how that occurred :thumbsup:
  9. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    It happened to me when I clicked a link in Google that brought me to a post on the forums. The link had the font size included within it.
