Avermedia Tvbox9 + AE700
Discussion in 'TVs' started by colmmacc, Oct 31, 2004.
  1. colmmacc
    colmmacc
    I have both the TVbox9 and an AE700 PJ on order and am wondering about the quality of RGB component -> VGA performance of the TVbox9. I have quite a long VGA cable routed neatly, under carpets, up walls that sort of thing and I'd really like to avoid laying RGB. Especically since I'm likely to buy a DVD player with HDMI some time next year.
    Does anyone have any experience with the Tvbox9? anyone know if it can passively feed through the RGB signal over VGA? Or will it insist on scaling and de-interlacing it? and if
    so, just how bad is this liable to be?
