Quantcast
Averkey lite vga to component
vishnu
Has anyone had any experience with this?
link
I am in the process of deciding on my first HCPC. Planning to use the DVI out on a ATI 9600SE to my Epson TW100 PJ.
Thought this adaptor would be ideal to connect to the panasonic tv i am buying as it has component inputs and only costs £35.
Any views would be appreciated.
CodeThief
Good price but ....
Supports resolution up to 1024 x 768 (PC & iMac DV) with 16.7 million Colors
So no 960/1080i for you then ;)
Dave
CodeThief
I've just had another look at that and it doesn't do YPrPb so wouldn't be much use :(
Dave
vishnu
Thanks for your reply.
It says on the web site,
Supports Composite Video, S-Video and YPbPr (Component)
or am i missing something?
Richard
CodeThief
My mistake, you're correct :)
Dave
