...you want menus as well.it would be better to burn it onto a bluray disc if ...
So with camcorders now filming avshd i was told you could only record about 30 minutes? if you want to put it on a dvd to play in a bluray player. Is this true?
AVCHD 2.0 is 50p/60p compliant since 2011 ;You can forget 1080p50 for AVCHD and Bluray (BD spec only supports progressive up to 24 fps).
AVCHD - Wikipedia, the free encyclopedia
I tried with 50p @ 28 Mbps burnt on dvd-rw (I created the AVCHD structure with TSMuxer) and it's played without problem by my 2 Blu-ray standalone players.
The duration at 28 Mbps on dvd-5 is short of course, but it works.
But one can burn it on Blu-ray (BD-25, nearly the same price than dvd-9) to allow longer durations, most of recent players should be able to play AVCHD structure burnt on BD-R.
AVCHD video, recorded onto Blu-ray disc can be played on most Blu-ray Disc players
That's why I was talking about AVCHD structure burnt on BD-R, it doesn't have to be compatible with the BD spec because it's not a Blu-ray structure.
Vegas 12 can surely output 50p files (if you need 50p disks, use Vegas only for video editing, not authoring), then open your mp4 or TS file in TSMuxer to create AVCHD (no menu) and burn it on BD-R with ImgBurn.
Ok, but I gave a trick for those who need 50p/60p on BD-R (TSmuxer support chapters and subtitles by the way).Yes it can, but you cannot create properly authored disks with animated menus, chapter points playlists etc, using DVD Architect Pro, unless you have 1080p24 source content. If I simply wanted to playback the content I would use a suitable media player and the original edited video, not much point in burning to optical media.
I have no intention on buying a bluray writer,So for now the only best thing to do is buy a usb pen or maybe a usb hard drive.
Yes its obvious and sensible to put all unedited video and also edited films onto external drives,regarding AVCHD i dont make any anymore only BD as another storage and easy playback method,but AVCHD discs can be burnt on PCs and laptops with a DVD burner.250 line res DVD is years out of date IMO.
Ok nit pick,BUT they are still SD and have nothing like the resolution of an AVCHD burnt on DVD,and quality is lost putting even normal 1920x1080P on them.250 line ?? In former PAL countries DVD is 720 x 576 25fps (same as best digital SD channels), In former NTSC 720 x 480 30fps (nominally).
250 lines isn't a valid resolution for DVD-Video disks.
DVD-Video - Wikipedia, the free encyclopedia
Ok nit pick,BUT they are still SD and quality is lost putting even normal 1920x1080P on them.
Well DVDs outselling BLU RAY does not matter to me people are easily pleased,my post was not completely inaccurate but partly saying 250 lines which is back to VHS days,standard DVD is SD though and putting 30 or so min of BBC HD on dvd in avchd format means nothing as that is HDIt's hardly nit picking pointing out that your post was completely inaccurate. Afaik DVD movies still outsell Blu-ray disks. If you put content like say BBC HD recorded live onto DVD disks in AVCHD format there is no loss of quality at all (provided you do not recode the content) , burning to Blu-ray will give identical results.
As for AVCHD being BLU RAY standard Blu-ray uses a MPEG4 compression. It's using the H.264 codec. Most blu-ray players can read up to 40Mbps. This is a lot of data per sec.
The AVCHD codec is heavily compressed. It's like trying to cram a beach ball into a garden hose. There's a lot of artifacts as well, which will only degrade the overall image quality. The max bit rate for this codec is usually 22-24Mbps. Most modern cameras use the H.264 codec and compress their video to a max of 48Mbps. This is double the amount of data then that of the AVCHD codec.
Can both H.264 and AVCHD do full 1080p (1920x1080), yes but the way the files are compressed is the difference.
Here's a detailed breakdown of a BBC-HD broadcast
General
Complete name : E:\DrWho\Doctor Who_Ep01.ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 1.41 GiB
Duration : 47mn 39s
Overall bit rate mode : Variable
Overall bit rate : 4 247 Kbps
Video
Menu ID : 6941 (0x1B1D)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 47mn 39s
Bit rate : 3 424 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.066
Stream size : 1.14 GiB (81%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 6
Duration : 47mn 39s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -1s 34ms
Stream size : 131 MiB (9%)
Language : English
Audio #2
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 47mn 39s
Bit rate : 256 Kbps
Channel(s) : 2 channels
Delay relative to video : -1s 2ms
Stream size : 87.3 MiB (6%)
Language : nar
Text #1
ID : 5403 (0x151B)-888
Format : Teletext
Language : English
Text #2
Format : DVB Subtitle
Codec ID : 6
Duration : 47mn 35s
Delay relative to video : 4s 485ms
Language : English
Sorry i have not used them,i load my files with a card reader to external drives like the Seagate expansion drives,also edited films go on drives but its best to keep 2 as anything can fail.Any suggestions on what usb pens would be a good stable one?
