D
Deleted member 27989
I've become an owner of a Sony HDR-TG3e since last Thursday and noticed that a lot of the questions were to do with how to handle these files. Or to be more accurate, how to handle the samples as found on the Internet by prospective buyers.
As such I though I better write up my experiences, unfortunately due to time constraints this weekend I will have to do it into multiple parts.
Part 1: How to import my demo file in iMovie 08
Part 2: How to import single .mts or .m2ts files in iMovie 08
Part 3: Playback and sharing, what are you options
First get the demo file if you have not already got it, you can find it here. Just navigate to the Sony HDR-TG3e directory and select the file memorystick.zip.
This file contains a direct copy of a memory stick from my camera with no changes.
Unfortunately iMovie 08 does not like to import direct from file, and since prospective buyers not yet have the camera you need to simulate that you have got the flash media. OS X has got all the tools built in.
Just launch Disk Utility and create a new image, for my sample make certain you can select any size from CD upwards. Depending on your system this can take a little while. Once the image is created it will automatically mount.
Then just copy the contents from memorystick.zip into it (don't forget to expand first
) and once the copy is completed you MUST eject the image file.
Now start up iMovie 08, then switch back to Finder and double click on the image file ([yourname].dmg), the volume you create before appears and iMovie 08 immediately states it detected a camera and will display the import dialog.
Use iMovie as per normal and enjoy
I've made a little screen movie demonstrating what you need to do on my screen, just waiting for it to upload before I can give the link.
