AVC Not Seen By PSP
Discussion in 'Playstation Forums' started by Forestred, Sep 7, 2005.
  1. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Help,
    I can sucessfully encode ripped DVDs in the AVC format within PSPVideo9 but when I transfer the files my PSP will not let me see them, I have used explorer to look at the PSP memory stick and the file is there but I can't see it within the PSPs video menu - what have I done wrong?
  2. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    I have done the same tonite no videos shown but there on the stick. Worked ok with the sp encoding.
    Have we missed something ?
  3. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    which file did you put them in ?
    i had to move them about to find them ..had the same prob earlier
  4. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    Hi, try this:
    For videos that begin with MAQ, be sure to put them in \MP_ROOT\100ANV01 in the "Destination" menu.
    For videos that begin with M4V, be sure to put them in \MP_ROOT\100MNV01 in the "Destination" menu.
    This is from an article about the new PSP video format here:http://psp.ign.com/articles/637/637459p1.html
    hope this helps :smashin:
  5. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    What a star, it works perfectly now - thanks very much
  6. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Still not getting it , right I"m converting movie in avc profile ok to correct directory ie 100ANV01, copy to card and put file in the above folder.
    But on the psp it shows no videos although I know its on card ?
    At what stage and how is the video renamed to MAQ ?
  7. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    The video is renamed MAQ or M4V by PSPVideo9 when it encodes into your selected format.
