AVC-A1SR power on problem Help?
Discussion in 'AV Receivers & Amplifiers' started by mcduck, Jul 27, 2004.
  1. mcduck
    mcduck
    Apr 23, 2004
    52
    Hi All
    I have the above denon amp I have problems with it switching on. Amp is powered on in standby. It will not power on from the remote. I have to switch the power off then back on for it to power up from the remote. Is this a problem that any body knows of?
    Luke
  2. Arcangel
    Arcangel
    Do you have anything nearby that might be interfering with the signal (plasma TV)?
    It's worth resetting the amp but write down all your settings before you do it as they're all reset to the factory defaults (channel levels, speaker setup, delay times, digital in assignments etc etc). When the unit is off, hold the Stereo & Direct buttons down on the front panel whilst pressing the Power button on, hold a few seconds and the display will flash. You'll then just have to key back in all your settings again. Hopefully this will cure it if it's a minor hiccup. :)
