Avc-a1se Probs
Discussion in 'AV Receivers & Amplifiers' started by zamwessell, Mar 18, 2003.
  1. zamwessell
    zamwessell
    Jan 2, 2003
    1,164
    +94
    I have a Denon AVC-A1SE and an Arcam FMJ-DV27.I connect these together by coaxial.
    I can be watching a dvd movie when at any random time,the Dolby Digital sound will cut out.If i immediately select any of the sound options on the Denon remote then it comes back on.While all this is happening i can still constantly hear the sound through my tv speakers(if i turn the volume up on the tv).The DV27 is connected to my tv by RGB scart.
    I do not think it is a problem with the discs as i can go back an hear the Dolby Digital soundtrack at the same point it cut off another time.
    I am wondering if the Denon is playing up or not connected correctly as this has only happened since i set it up again after testing the Arcam AV8/P7 combo.
    I am at a loss as to what the problem is.
  2. Jase
    Jase
    Mar 16, 2001
    9,466
    South Coast
    +891
    Could be the digital cable between the Arcam and the Denon? Have you tried a processor reset? Sometimes the amp can throw a wobbler and this can cure it. Hold down the Stereo & Direct buttons whilst turning the Power on and the display will flash.
    Make sure you right down ALL your settings, channel levels, delay times etc as they will be reset to the defaults.
  3. zamwessell
    zamwessell
    Jan 2, 2003
    1,164
    +94
    Woo!! Thanks for the quick response.I will try a reset.Thanks.
  4. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    if it's an rgb scart you won't hear any noise through the TV as rgb scarts aren't wired to carry audio. it does sound like the amp is causing the problem.
  5. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Unless it's an RGB Scart + Audio cable ;).
    Make sure the Dig Out on the Arcam is set to Bitstream and not Stero PCM.
