AVC-A1SE headphones
Discussion in 'AV Receivers & Amplifiers' started by ronthecod, Mar 8, 2006.
  1. ronthecod
    ronthecod
    Mar 7, 2006
    5
    I have been trying to connect a stax headphone energiser to my AVC-A1SE and it is doing my head in. I can,t seem to find the correct way of getting the signal out to the stax unit. looking for ideas on how to solve this but please keep it simple.
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Are these not supposed to use a line level output, usually provided for a tape deck?
  3. ronthecod
    ronthecod
    Mar 7, 2006
    5
    I think so but i can,t get any thing of from the tape out connections, and will this still level the unit playing through the speakers.
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Not with you. Do you mean will it mute when you want to listen via headphones? I would refer to the taping sections of the manual, and you should be able to mute the amp without affecting the tape loops...
  5. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Whats the source coming in on?
  6. ronthecod
    ronthecod
    Mar 7, 2006
    5
    pioneer cd using a digital conection
  7. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Try listening to something connected via analogue.
