AVC-A11XVA: How do I use sub when watching MTV!
Discussion in 'AV Receivers & Amplifiers' started by skel00, Dec 24, 2006.
  1. skel00
    skel00
    When I watch a broadcast such as MTV I don't hear the sub. I have played with the settings but the best I can get on a non DD broadcast is stereo from the 5 speaker channels. Is there any way to get the sub working on music?
  2. jackal
    jackal
    Have you set the subwoofer to LFE & Main in the Denon's menu?
    Edit: Also if you have your front speakers set as large, the output to the subwoofer will not be that obvious in stereo.
  3. skel00
    skel00
    Hey
    Thanks for this, its coming in now... Turned the fronts to small too. Still the subs not all that noticeable unless I turn it to max, B&W PV1. Thing is its set fine for movies, if I play a DVD in this setting it'll shake like crazy. Can I set the sub to be at different levels depending on which setting I chose rather than doing a channel level change all the time?
    Richard
