AVC-A11XV Direct Mode Sub out
Discussion in 'AV Receivers & Amplifiers' started by Jasy, Aug 13, 2005.
  1. Jasy
    Jasy
    Help anyone,
    I am a proud owner of a new AVC-A11XV. I notice there is no subwoofer output in direct/direct pure mode despite turning on the subwoofer in the surround parameter or on the channel level menu. Is my set faulty? :lease:
  2. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    Doublecheck that you haven't got the Sub set to OFF for the Direct/Pure Direct Modes. Go into the main Setup Menu, Advanced Playback, 2CH Direct/Stereo. From there, you can change the settings.
  3. Jasy
    Jasy
    I have done all that and my sub is still out. Looks like I have a faulty unit. Otherwise I think it is a great amp. I have it connected to Tannoy arena speakers with Marantz DV 9500 is DVD player and Roksan Caspian M1 as CD player. Cracking good sound! Thanks anyway. :smashin:
  4. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    Do the Channel Level Test Tones produce anything for the SW channel when you run them?
  5. Jasy
    Jasy
    Guess what, I followed your advice, reconfigure it again in the the advance menu and it worked this time. Thanks a million! :clap:
