AVC-A11SR Multizone
Discussion in 'AV Receivers & Amplifiers' started by rnjones, Dec 15, 2001.
  1. rnjones
    rnjones
    Hi , this is my first post, so sorry if it is a bit daft.
    This morning I went and spent my hard earned savings on a AVC-A11SR. I have spent most of the day having a wiring party, excellent!
    Anyway all is working apart from the multiroom bit. My Kitchen is right behind my TV room and I have spekers installed in the kitchen so I can get down whilst cooking etc.
    Now I read loads of comments, PDFs etc and got the real impression from lots of sites that you could "dedicate" two channels of the 11SR to multi room.
    I only have a 5.1 setup due to my poor negotiating skills around adding extra speakers :(
    So the two extra channels I would like to use for CD playing in the kitchen. This also works well as she can cook with music and I can watch Arnie :)
    I can see how to do it with Pre outs to another amp (negotiation failings will put paid to this idea). But the dense Denon manual does not seem to cover the asignment of amps to multi room.
    Has anyone done this? Any Clues. Should be similar to A1Se.
    Will do some more fiddling.
    Got mine from Audiofile in Bishops Stortford (top place) £1800.
    Thanks Rog
  2. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,487
    Has it got the option in the set up menu for Power Amp assignment?
    I think you select this and connect the extra set of speakers to relevant terminals on the unit.
    Double check the manual for more details as i cant remember any more!!! (my old 3801 had the same option)
    cheers
  3. rnjones
    rnjones
    Hi Jase, no it hasnt, ben fighting this for days. Seems to have a different firmware laod or something. Waiting for a comment from my dealer.
    Rog
  4. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,487
    Odd one this!!
    The american version gives you the option for power amp assignment as does the US version of my A1SE.
    To use multiroom on my amp i´d need a 2nd separate amplifier.
    Just seen your post at the Flagship Central Forum, maybe you have got a different firmware!!??
    Hope you sort it soon!!
    cheers
