AVC A11SR Multi Zone Output
D
djc101
How can you assign unused surround speaker terminals to the multi zone output of the amp instead of using a seperate amplifier plugged into the multi zone output?
(Jasse, you have answered a similar question for me prevoiusly, but I can't find the menu items you refer to. Mine is a UK model Amp and there doesn't seem to be an option in the ststem setup menu under speaker configerations on multi zone volume leval).
Dan.
IMHO that doesn't work. The AVC-10SE had a function were you can re-route the power amps, but multi-zone usually requires an external power amp which can be driven by a 2nd source.
Multi-room refers IMHO to using the internal amps to drive a 2nd pair of speakers (like e.g. front A and B).
Hi Dan
Which surround speakers are you referring to?? Surround Back or Surround B?
Surround Backs amps can be assigned to drive a set of speakers in another room, its done from main setup menu, Power Amp Assignment, set to Multi. The speakers still remain connected to the Surround Back terminals.
Surround B can´t be reassigned, its a fixed output (actually use Surround A amps).
Jase, There is no power amp assignment in my setting menu. Is it possible that your Amp is not a UK model and hence has some options that mine does not?
Dan
Dan
Looks like you didn´t get that option on the UK spec model:( . Just had a quick look, the american spec gets it.
To use multiroom you´ll have to connect up a second amplifier and use the multizone output.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
