Availability Sony STR-DB795
Discussion in 'AV Receivers & Amplifiers' started by Tug100, Oct 2, 2004.
Tags:
  1. Tug100
    Tug100
    Oct 2, 2004
    20
    First timer - learning a lot - great forum.
    I'm about to buy my first home cinema set up to go with Pioneer DV-464 dvd player.
    I've settled on Sony STR-DB 795 receiver to go with Mission Cinema M30 speaker package, or MS Premier Plus, or if needing to compromise maybe the Tannoy FX5.1.
    My question is..... where can I get hold of the sony receiver. The Sony shop says its not available yet, and so does Superfi's web site.
    Is it available or do I need to wait?
    Cheers........
  2. TheeNoMaD
    TheeNoMaD
    Try hi-spek i was told they might have it. But it might be just in black.
    Hope im right
    sos if i couldnt help
  3. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,650
    38
    +13
    multizonedvd.co.uk they might have it
  4. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
