AV8 with P35 & P25/3 - will they work together
Discussion in 'Arcam Owners' Forum' started by ihan, May 20, 2005.
  1. ihan
    ihan
    Sep 10, 2004
    624
    28
    Stockport
    +25
    Hi folks,
    My FMJ (on the cheap) crusade is progressing.
    A second hand AV8 is on its way :clap:.
    I already own a P35, DV29 & a CD23.
    An ex-demo P25/3 is available at a reasonable price.
    Does anyone know if an AV8 + P35 + P25/3 will work together. In other words, will they all switch on (& off) together if daisychained via their remote/trigger sockets?
    I am assuming they all have the same gain?
    Regards,
    Ian
  2. Timmy C
    Timmy C
    Oct 10, 2003
    4,519
    +218
  3. ihan
    ihan
    Sep 10, 2004
    624
    28
    Stockport
    +25
    Hi Timmy C,
    Thanks for the info. That is "quite remarkable".
    Can anyone else confirm? I just thought that it was a 12V signal whose rising edge turned the amps on, and whose falling edge turned them off; reading the AVR300 manual led me to believe this.
    Can anyone at Arcam tell me what the P25 & P35 protocols are so I can set about designing a little external converter board?
    I will put the P25/3 purchase on hold until I get more info.
    Regards,
    Ian
  4. ihan
    ihan
    Sep 10, 2004
    624
    28
    Stockport
    +25
    Hello all,
    I contacted Arcam's customer service department by 'phone today and a gentleman called Steve or Stephen (not sure which) looked at the P25 manual and told me it should work fine, so now I'm as confused as ever. :confused:
    I'm not sure whether to proceed with the P25 purchase or not. Could anyone else confirm?
    Regards,
    Ian
  5. RadBadMark
    RadBadMark
    Feb 28, 2004
    83
    +4
    I haven't come across any problems using P25's with the AV8 - 4 daisychained from the zone 1 trigger, and they switch on/off just fine.
    Can't comment on using P25s and 35s together, but can't imagine it would be a problem.
