AV8 Remote Peeling
Discussion in 'Arcam Owners' Forum' started by BladeRnR, Jul 8, 2005.
  1. BladeRnR
    BladeRnR
    I have just noticed over the last month that the finish on the remote for my AV8 is starting to peel. It's also starting to get rough around the edges and one side I've had to put some tape as the skin finish came off. I guess my question is can I get another remote or is there some way to counter this problem. I actually liked the oil skin finish on the remote but now I'm questioning it's longevity. Thank in advance.
  2. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    Ditto here.. im considering using it till its in pieces or just getting the logitech colour model...
    I dont think it will be covered in warranty? but if it is then intresting.
  3. MrKegFlex
    MrKegFlex
    I just happened to notice this today on my CR80 remote. I thought it was a grime buildup on the remote until I noticed it was actually the finish flaking off. Anybody know what causes it or is it just a bad batch of remotes?
    Is this kind of defect covered under the warranty?
  4. mjn
    mjn
    May 24, 2001
    17,967
    Herts, England
    +4,938
    You're telling me, its not a polished metal remote? £3k for a processor, and its a plastic remote?
  5. DrBosa
    DrBosa
    My CR80 is peeling as well. Bought the damn thing in October -04 (together with my AVR250) and it is already starting to look like crap.
    I'll let you know if the warranty covers it because I'll return it for sure.
  6. MrKegFlex
    MrKegFlex
    It would be interesting to find out how many forum members are experiencing this problem. When I emailed support, I got this response -
    "This is the first case I've heard of the outer layer peeling on the CR-80 remote.. The only thing that might of done this is intense heat, or heavy wear and tear. Regretably, the unit is not covered under warranty for this sort of peeling."
    There is definitely nothing hot on the end-table where my remote is kept so that can't be it. I've owned my unit for less than 1/2 a year... play a few cds a few times a week and 2 or 3 movies on the weekend. I hope that doesn't qualify as heavy wear and tear.
    It's a shame it's doing it, it's a nice remote.
  7. MrKegFlex
    MrKegFlex
    Actually, I'm confusing it with another purchase. I bought my avr300 in mid-april of this year, so my cr80 has only seen a few months of use before experiencing the peeling problem.
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    My CR-80 that came with the AVR300 has started peeling, I just got another one instead and put in the box. I now use a Marantz RC9500 to control everything.
  9. MrKegFlex
    MrKegFlex
    I received another email from Arcam support, they are wanting me to go through my dealer to send my remote back. They seem unaware of this problem and would like to see what is actually happening to the remote.
    I'm not sure how common this problem is... or, if people have bothered to complain when it happens. So, hopefully, this will help find a solution... whether it's isolated incidents or a bigger problem.
  10. Hifi addict
    Hifi addict
    maybe your wife was over enthusiastic with some cleaning chemicals, thinking she was helping you to clean your most loved device in the house ;)
  11. DrBosa
    DrBosa
    Tell her to only use dihydrogen-monoxide :D
  12. MrKegFlex
    MrKegFlex
    Received my replacement remote today... the original is on it's way back to Arcam.
    The more I think about it, I'm starting to wonder if the coating on the remote has a reaction with furniture polish (or a particular brand of polish). My remote sits on my end table which gets wiped down with furniture polish occasionally... and the peeling started where the remote makes contact with the end table. Weird if that is the cause, none of my other remotes have a problem with it.
  13. liteswap
    liteswap
    Jun 21, 2004
    327
    East Sussex, UK
    Mine's doing the same, and I've only had it a few months. There's no furniture polish on it either, that's for sure so, MrKegFlex, I'd guess that's not the cause..
  14. MrKegFlex
    MrKegFlex
    I would contact Arcam support and let them know. According to them, I'm the first one to experience this problem and report it to them.
  15. liteswap
    liteswap
    Jun 21, 2004
    327
    East Sussex, UK
    Have now done so -- we'll wait and see.
  16. liteswap
    liteswap
    Jun 21, 2004
    327
    East Sussex, UK
    I've had the following response from Arcam tech support:
    This is only the second time I've heard of one peeling..
    If you can get it back to your Dealer they should replace it for you..
    Forward this e-mail onto them, or say you've spoken to Arcam.
    Arcam Customer Support
    A&R Cambridge Ltd, Pembroke Ave, Denny Industrial Ctr, Waterbeach,
    Cambridge, CB5 9QR, UK
    So I'll report back...
  17. MrKegFlex
    MrKegFlex
    Seems weird so many on the forum are experiencing it. Either we are the exception or people aren't bothering to report the problem.
  18. liteswap
    liteswap
    Jun 21, 2004
    327
    East Sussex, UK
    My local friendly dealer (powerplant in Hove) is happy to replace it, after calling Arcam to get a new one. Full marks to them for customer support.
  19. DrBosa
    DrBosa
    I have contacted Arcam support, see email conversation below:
    (my original email)
    Hi, Are you aware of this problem?
    http://www.avforums.com/forums/showthread.php?p=1800066#post1800066
    http://www.prisjakt.nu/forum/index.php?showtopic=98788&hl=cr80
    I will need to return this remote and have it replaced.
    BR
    Magnus Eriksson
    Sweden
    (reply from Arcam)
    Hi Magnus
    Please contact our Swedish Disributor Ljudtema for a replacement. The best thing to do is go on our website. Go to find a dealer, on the top left of our home page. You will need to put in your country of origin, and hit search. The Distributor at that website address/telephone number will be able to help you. Our Distributor's have Technical Support should you need to contact them in the future.
    Regards
    A&R Cambridge Ltd, Pembroke Ave, Denny Industrial Ctr, Waterbeach, Cambridge, CB5 9QR, UK
  20. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,811
    2
    167
    Birmingham, UK
    +9,530
    Err do you think it is wide/good manners to publish an email which has a confidentiality note at the bottom?
  21. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    I would suggest removing the post and PMing author stating why.
  22. Timmy C
    Timmy C
    Oct 10, 2003
    4,397
    +200
    I'm not being funny but it seems fairly obvious that the confidentiality note is a standard note that is attached to all emails they send out and I can't see anything in this particular email that Arcam would want to keep private.
    I think Magnus is just trying to help others in the same situation.
  23. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Hi all,
    I have slightly editted the copy of the mails above to remove the confidentiality statements and the names of the Arcam support person. As Stuart has mentioned, it is good manners really :) But as Timmy has said it is useful for others, and as such I have left in the core of the message to help others in the same situation.
    Andy
  24. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,741
    63
    +230
    Scuse my ignorance on this matter but what part of your CR80 remotes is peeling?
    Mine seems ok with no sign of any peelage!
    Regards
  25. liteswap
    liteswap
    Jun 21, 2004
    327
    East Sussex, UK
    Quite right: as I said in my PM to you, I should not have disclosed the engineer's name - it's bad etiquette. Apologies to anyone affected.
  26. BladeRnR
    BladeRnR
    The peeling is on one side of the remote the other is getting rough and will follow suite I'm sure. It's losing the oil skin finish the more it is used. Thats in my case.
  27. Greggles
    Greggles
    Mar 15, 2005
    1,069
    St. Saviour, Jersey
    +74
    I currently have 2 CR80s (one of which replaced a faulty unit about 6 months ago) none of which have suffered with this issue. In deed, one of the units in question has been subjected to a bit of a chew from one of my crazy dogs (Belgian Shepherds) but still works perfectly and has not peeled. I wonder if there was a faulty batch or whether the effected units have all come into contact with a common chemical - ie houshold cleaner?
  28. BladeRnR
    BladeRnR
    One would think that it would be some sort of cleaning product, but I've never used one on that remote due to it's oil skin surface. Maybe its just oil and sweat from my hands that has caused the problem. Anyway I will be asking the Hi-Fi joint about getting a replacement and see what they say.
  29. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Also alot of ppl I would think probably do not use the remote once its been added to their pronto/learning remote of choice.. so hence maybe why not that many have noticed.
    Matt
  30. MrKegFlex
    MrKegFlex
    Mine started to peel where it makes contact with the table it's resting on. Because of that, I wondered if it wasn't a very robust finish that reacts to furniture polish or something.
