Av8 popping sound
Discussion in 'AV Receivers & Amplifiers' started by jeroen999, Feb 28, 2003.
  1. jeroen999
    jeroen999
    Dear people,
    I'm the proud owner of a second hand AV8 and I have a problem.
    Normally I would turn to my dealer ,But as this is a second hand
    I do not think he wil appreciate it.
    Can't turn to the Importeur to ,because they will say "find out where it is bought and call them !"
    So here I am and this is the question,hope someone know's.
    I connected the Av8 to 2 amps a av 50 and an naim NAP175.
    The problem is when I'm in the setup menu, and for instans set the sub level on another level (50 herz...60 herz) I wil get a enormous plop over the speaker and woofer.
    I first thought this was a foult of my woofer
    But when I was setting the level of my speakers I noticed that there also was a hard TIC when I switched back and forward through the menu,especially when I set the levels and then switched to the top of the menu.
    I also had a strange thing on my center,when I was routing the test tone through the center, the tone was first oke but after a few seconds it got softer an gave some kind of distortion hiss
    WELL hope someone can help me
    kind regards jeroen
  2. sr78
    sr78
    Sep 26, 2002
    281
    Didn't you get the warranty forms when you bought it? As we say in Holland, it didn't fall of the back of a truck, did it? ;)
    Seriously, it does seem there's something wrong. Seems like static interference from somewhere. Did you ground all your equipment?
  3. jeroen999
    jeroen999
    Thanks for the reply!
    HAHAHAHAHA ,No if it was fallen out of a truck ,it certainly was damaged
    :laugh:
    Certainly have the warranty forms but this doesn't mean they are glad if I call them with questions the importeur I mean.
    How do you mean "ground it".
    Is this someting that is neccesary?en how do I do this?
    Doesn't it use the ground that in in the powercable?
  4. sr78
    sr78
    Sep 26, 2002
    281
    If you have the warranty stuff, you can just visit any Arcam dealer and they are obliged to service the product for you, as long as the warranty hasn't expired for some reason.
    The importer will tell you the same, there's no reason to contact them over a faulty product.
    Grounding (aarde in het Nederlands) means making sure you amp is connected to a socket with a ground wire (in Holland, this means the pins on the top and bottom of a socket).
  5. jeroen999
    jeroen999
    thank's .
    I will do this,and let you know what it was!
    greetings jeroen
  6. sr78
    sr78
    Sep 26, 2002
    281
    Problem is, in most Dutch houses there are no sockets with grounding in living rooms.
  7. jeroen999
    jeroen999
    if this is the problem ,how do I solve this ?
  8. sr78
    sr78
    Sep 26, 2002
    281
    Depends: does the room where your AV8 and other stuff is have a grounded socket? If not, you can't ground it.
    As I'm rereading your problem, I'm reminded of the problems with the Marantz SRx200 AV amps. These model had a bad condensator, which led to plops when switching between DD and stereo. I think it's probably an internal problem with your AV8, and that grounding doesn't have anything to do with it.
  9. jeroen999
    jeroen999
    Good thinking ,just got a mail from MR.Dawson.
    He thinks it is maybe a soft or hardware problem.
    Gave me some hints to sort out the problem.
    will come back on it when I know what it is .
    Thanks sr 78 for thinking !!!!!!!
    vr gr jeroen
  10. Halcion
    Halcion
    Oct 11, 2001
    78
    9
    Jeroen,
    I described a similar kind of problem with AV 8 when I demoed it in Holland.
    I never got any information back from Arcam, so I would appreciate if you could fill us in on this.
    I'll hopefully try and get a second home demo of this unit soon (my first one turned afoul due to bad mismatch with my power amps).
    regards,
    Halcyon
  11. jeroen999
    jeroen999
    Offcourse I will,
    I hope that I know next week everything!
    I will let you know!
    vr gr jeroen
