AV8/P7 Speakers advice
Discussion in 'Home Cinema Speakers' started by John Howard, May 21, 2005.
  1. John Howard
    John Howard
    May 14, 2005
    Hi, I am about to purchase an Arcam AV8/P7/DV29 combo and just wanted to know which speakers should I get. My room is 5 by 5 meters, at the moment I am planing to get one of these 5.1 setups:
    B&W 804S fronts
    B&W 805S rears
    B&W HTM4S
    ASW855
    OR
    KEF 203 fronts
    KEF 201 rears
    KEF 202C
    PSW4000
    Also for the cables I am planing to get them either from chord or audio quest (haven't decided which models yet).
    Opinions & suggestions please
    Many Thanks for your help :smashin:
  2. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Both sets of speakers are really accomplished, although I would avoid the KEF sub :) Also keep in mind thats a really big set of speakers for your room so I would be thinking hard about how to control room modes especially with a big sub. I think s BFD will be required :thumbsup: The best advice is to have a listen to both sets yourself. Are you buying from Sevenoaks by any chance?
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    How many other makes have you considered?
    Personally, that choice seems so stereotypical.
    Have a look at the likes of PMC, Dynaudio or my favourite ATC for example.
    Also, have you considered using the AV8/DV29 with good active speakers?
    Genelec or ATC again for example. I think you might be suprised at just how good that will sound.
    I just don't want you to end up with the same as everyone else just because it's the most popular combination. B&W and KEF are good, but there are plenty of others that better them for the same money imho.
  4. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    I would second the ATC recommendation :thumbsup:
