AV8/P7 low level listening
Discussion in 'Arcam Owners' Forum' started by sticker, Jan 12, 2004.
Tags:
  1. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Recently tried to use my system to just have very low level background music when some friends were around. BUT unfortunately I found that even at its lowest setting 0.5/-52db the sound level was intrusive. Anyone know of a way I can lower the sound levels or have you found the same issue.
    Regards
    John
  2. kryten
    kryten
    Apr 9, 2003
    557
    Swindon
    +18
    I find that's the case when using the digital input (especially from Sky+).
    Have you tried the analogue input - you could try changing the output of the source (eg on Sky+ you can turn down the volume output) or change the sensitivity of that input (ie increase to 4v).
  3. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Hi Kryten,
    Yep tried the analogue input and it is indeed quieter but still intrusive. I'll try the sensitivity input.
    John
  4. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Cheers Kryten, changed the input trim on the CD to 8v and that sorted it.
    Regards
    John
