Av8 menu setting
Discussion in 'AV Receivers & Amplifiers' started by jeroen999, Jun 30, 2003.
  1. jeroen999
    jeroen999
    Dear people,
    I have a " problem" .
    The AV8 should have the possibilety to put a certain setup behind each button.
    Let me explain what I mean .
    lets say that I like a different set up than my wife, less bass.
    I will make a set up in the menu an call it for instants "jeroen" .
    For my wife I will make one that is called " aline"
    I want to have my "jeroen pre select" behind button " AV"
    And the "aline pre select" behind button "cd"
    So if I push 'AV" the processor automaticly will use the " jeroen pre sellect"
    This should be possible to do in the first page from the setuo mode.
    I can't get it working ,does anyone know how its works?
    Hope you can help me .
    kind regards jeroen
