AV8 hints, tips, FAQ's
Discussion in 'Arcam Owners' Forum' started by sticker, Oct 21, 2003.
  1. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Thought it may be a good idea for AV8 owners to exchange information and tips on this complex beast.
    The following site has some excellent info
    http://www.aslgroup.com/arcam/av8p7.htm#stuff
    Anyone else got any other hints etc?
    Regards
    John
  2. kryten
    kryten
    Apr 9, 2003
    515
    Swindon
    +14
    Must admit I found that website very helpful - its better than Arcam's own site (hint hint!)
    You can get the 12v trigger to operate a poweramp when either Zone 1 or Zone 2 are on by simply wiring both signal pins together on the 3.5mm jack.
    The AV8 only outputs video on the highest quality output that is available. This means if you had old Composite and SVideo to SCART cables, they may no longer work (if the Sync signal is only supplied by the CVBS cable).
