AV8 - Help with component connection
Discussion in 'Arcam Owners' Forum' started by RAM69, Jul 23, 2004.
Tags:
  1. RAM69
    RAM69
    I have just got my AV8 and am very impressed with it. However, I have got a problem with the component video output.
    When I connect my Pioneer 868 to the AV8 via component and then output via component to my SIM2 extra, the pj does not get a signal. If I connect the 868 direct to the pj the signal is fine so I know the cable is OK.
    What am I doing wrong which prevents the AV8 from passing the signal through?
  2. crion
    crion
    Jun 6, 2004
    23
    Did you define which component input to use for the source? And also what type of connection (Component or RGB)?
  3. RAM69
    RAM69
    I showed the input as DVD and it is connected via component.
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    You need to turn on the DVD component input if you haven't already done so. This is in advanced menu 2 Video Settings at the bottom. Set HQvideo 1 to DVD. (if you are using input 1)
    Also make sure that in the menu 1 the general settings menu the HQ video setting is set to component.
    Regards,
    Andrew
  5. RAM69
    RAM69
    Thanks for this.
    Amazingly enough, the shop came back to me last night and we discovered it was the setting under menu 1 that was wrong. I have now changed the setting and it works fine.
    I must say I am very impressed with the processor and would recommend it to anyone.
