AV8 + DVD-Audio = No Sub output ???
Discussion in 'Blu-ray & DVD Players & Recorders' started by RustyZip, May 2, 2007.
Tags:
  1. RustyZip
    RustyZip
    Jan 10, 2006
    441
    Worcester
    +16
    Hi...
    This should be a quick easy question for you Arcamites:-
    Ive only just started to experiment with a subwoofer in my system, and its fine with normal DVD's (using a digital connection), but i cant get it to work with DVD-A (obviously using analogue connections)..
    Is there a way to turn off "Direct Mode" when listening to DVD-A, so that the bass management kicks in ???
    If not, then how can you get round it ?? I know i can connect the sub to the DVD Player, but then can i also connect it to the CD Player and AV8 at the same time ???
    Im assuming theres an obvious answer, but i cant figure it out !! :)
    Cheers...
  2. tvh3ad
    tvh3ad
    Jan 19, 2005
    339
    +15
    To get the sub to work for DVD-A, you need to do the following:
    1. Connect the analog player outputs (including the sub output) to the multichannel inputs.
    2. Go into your player's setup menus and specify that a sub is present. Also set the sub/stereo behavior and distance. (No need to modify trims; the AV8 handles those.)
    3. Connect the AV8 sub output to your sub LFE input.
    DON'T connect the sub directly to the DVD player! The player is not a preamp, so there'll be no way to control the gain.
    By design, there's no way to disable direct mode for the multichannel input.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Make sure that you have the Subwoofer level for the DVD-A input set to the +10dB setting on the AV8. This is covered on page 15 of your AV8 manual.
  4. gpa
    gpa
    Nov 23, 2005
    2,835
    +308
    According to Arcam you need to also set the trims as well if using Analog.:smashin: I rechecked after someone gave similar advice and I thought I had got it wrong.
  5. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    I also thought you were right and that "someone" :) was wrong. However, having run numerous tests here with a Sencore £2,000 RTA analyser "someone" is indeed right and whoever you spoke to at Arcam is IMHO wrong (at least with an AVP700 / P1000 setup). The AVP700 settings for trims ARE applied to analogue inputs from my DV139.
  6. gpa
    gpa
    Nov 23, 2005
    2,835
    +308
    Hmmm thanks for the heads up:smashin: it apears that not one but two different people from service/support were wrong then.
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    This has been covered by me before. The Multi-Channel inputs of the Arcam AVRs and processors still have the trim level settings that have been set on the AVR/processor itself applied to them. This means that on the player itself you only need to set the speaker sizes and distances.
  8. gpa
    gpa
    Nov 23, 2005
    2,835
    +308
    It has indeed, hence my second call to Arcam, thanks for the heads up though.
  9. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Thanks for the heads up on this, I will speak to the guys in support as you are correct the AV9 does put the level trims onto the Multichannel input.
    Regards,
    Andrew
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    As do all of the other current AV Receivers from Arcam. :thumbsup:
  11. RustyZip
    RustyZip
    Jan 10, 2006
    441
    Worcester
    +16
    Wow.. Thanks for all your replies..
    D'oh... After reading through - the problem was i hadnt connected the DVD's analogue SUB output to the Amps Multichannel SUB input !!! Having no sub before, i didnt need an extra cable there, but of course now i do...
    Thanks all for helping a clot !! :thumbsup:
