AV8 analog input problem
Discussion in 'Arcam Owners' Forum' started by cramus, Dec 3, 2004.
  1. cramus
    cramus
    I have a P7+AV8 combo and and a DV 79. I connected the player via coax for the movie sound and via analog to the multtichannel input for DVD-audio. both work fine. However, when I connect the anaolg output of the DV79 to the CD analog input (i tried DVD analog, tape as well) I get no sound. I would like to use these inputs since on the multichannel side, no tone control is available.
    I tried holdong the CD button for a few seconds to force the switch to analog bu it does not make any change. Do I miss any confirguration or is the AV8 faulty?
    Thanks for you insights!
  2. cramus
    cramus
    :lease: Any AV8 user or Arcam dealer out there to help me? I would highly appreciate guys.....Thanks in advance
  3. gazzerr
    gazzerr
    Aug 29, 2001
    179
    16
    Damascus
    It should work - are you sure the analogue cables are connected properly. What happens when you disconnect the digital cable and play a DVD/CD?
