AV500 Docking Pod and re-charging
Discussion in 'Video Streaming Boxes & Services' started by dlm999, Apr 25, 2007.
  1. dlm999
    dlm999
    My AV500 seems to have developed a problem of late.
    It will not charge through the docking pod - I can charge it if I take the power cable and plug it in directly to the av500, but when using the connector from the powered docking pod it does not.
    I can still use the docking pod to watch content through the TV, it just won't charge the av500!
    Anyone else seen the same problem or similar?
    Duncan
  2. Butters
    Butters
    Nov 16, 2005
    1,479
    Epsom
    +165
    Not had that problem before.........there's not much can go wrong though if you are using the same PSU directly and it all works okay. the only thing I can think of is to clean the power pin on the docks multi plug and see if that makes a difference.
