AV32R Setup Manual
laalves
Hi all,
Just bought a AV32R-EX from a german guy, with german manuals. I managed to get the operating manual from IAG's site, but no setup manual.
Can anyone help? A nice pdf would be super!
Luis
babaroga
Can you drop me a pm with your email so I can post it to you both setup and operations one ?
regards
Darko
AMCross
luis check you email :)
N
nmfns
I've the same problem, new on AV32R and no setup manual. Could anyone send it to me ?
Regards,
Nuno
edward
No problem - which version of software are you running?
I've got set-up and operating and diagnostic manuals
some are 3.4 some are 3.7.
PM me.
laalves
Diagnostics manual? What is that?
Luis
Thunder
Its best just to follow the set up wizard on screen as its identical to the manual in any case :) It will take you through every step of set up with explanations for everything :thumbsup:
edward
Luis
Title reads AV32R Specifications and Diagnostics
It basically tells you what the various conditions mean
and what you should do about them.
The container file was called um_av32r_reference_v37.zip
I trust this helps.
