AV32R OSD help
Discussion in 'TAG McLaren Audio Owners' Forum' started by UrbanT, Jun 22, 2004.
  1. UrbanT
    UrbanT
    Jan 6, 2002
    13,279
    Aldershot, Hants
    +3,033
    I'm struggling to think of an answer to this, I'd be grateful for any help.
    At the moment, to see the OSD, I have to lug a heavy TV to sit in front of the Tag, and use an svideo lead to connect. LIfe would be much easier if I could connect the Tag to my LCD screen for the PC. The LCD only has the normal blue PC connector, and a DVI input.
    Is it possible to connect the Tag up using svideo, or the other yellow RCA type connector (what is the correct technical name for this output/input?)
    Any help appreciated :)
  2. UrbanT
    UrbanT
    Jan 6, 2002
    13,279
    Aldershot, Hants
    +3,033
    Scrub the question. I've realised I have a spare svideo connector on the Sweetspot capture card, so will try and connect them when I get home :)
  3. AMCross
    AMCross
    Dec 3, 2003
    6,030
    Livingston,Scotland
    +208
    Quote "or the other yellow RCA type connector (what is the correct technical name for this output/input?)"
    I seem to recall its called composite Video
  4. MartinFXDX
    MartinFXDX
    Jun 6, 2004
    325
    +4
    Just an idea, I use a Progressive Scan Video to XGA scaler box between my pc and LCD screen. The PC input just routes through with sound. Other inputs (through a simple 4 way switch) eg AV32, DVD32, SACD/DVD player etc feed into the box so I can monitor any source including setup menus and DVD(A) content without turning on my TV or PC. The one I use was from Keene Electronics part VTB100. It also has a TV tuner and teletext.
    It works well enough for this sort of thing.
  5. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    I just have a little 7" LCD TFT monitor which was only £130, it has RGB,S and composite inputs. I use it so I can accesss the menu system without having to turn on my projector and burn up valuable bulb hours!
