AV32R latest software
Discussion in 'TAG McLaren Audio Owners' Forum' started by chipchap42, Jan 9, 2012.
  1. chipchap42
    chipchap42
    Jan 9, 2012
    3
    Hi folks,
    I have an AV32R DP with an older version of the O/S - 3.75. It's perfectly stable but if I try to play a new blu-ray DTS disc through it (Downton Abbey) then I can't select anything other than stereo. It says it's switching between stereo and DTS but I can't tell any difference and nothing comes out of the centre or rear spkrs.
    Am I right in thinking a newer version of the O/S would help? If so, anyone know where I can download one from?
    Many thanks for any help.
    Paul.
  2. Mr_Orange
    Mr_Orange
    Mar 23, 2008
    3,027
    Brisbane
    +277
    Not only newer, but I think you need the unofficial fixed version of the software that addresses some DTS related issues. There is a thread in this forum if you search.
  3. Miron
    Miron
    Sep 26, 2002
    1,435
    Vienna, Austria
    +54
    chipchap42, DP processor never worked with anything lower than 4.x, so I assume you have SP processor
