AV32R Input select
Discussion in 'TAG McLaren Audio Owners' Forum' started by maj74, Feb 6, 2005.
  1. maj74
    maj74
    May 27, 2002
    721
    Ipswich
    +23
    Help with AV32R INput selection...
    I have finally got an dolby digital feed from my x-bex into my AV32R.
    I got my AV32R second hand about 19 months ago and set it all up, with inputs titled and so on. All the analogue AND digital inputs I set up then work fine and can be selected both by the original remote and by my all in one porgrammed remote.
    The problem I now have is that I can choose the new x-box digital input, (it's connected to the 'md' input on the back of the tag) with the digital button on the front and the sound works fine. However pressing the 'md' input button on the remote has no effect. The remote button lights up, the 'reciever' light on the front of the tag flashes to say it's recieving a signal, but the input doesn't change...
    It's not a huge problem, I can change the input on the front of the unit, but I'd like to be able to solve the problem...
    Anyone got any ideas?
    Thanks in advance...
    Martin
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Martin
    Go into the set-up menu and check the Remote Key Assignments and make sure that the MD input relates to the right remote input
  3. maj74
    maj74
    May 27, 2002
    721
    Ipswich
    +23
    Thank you thank you thank you...
    Problem sorted!!!
    Damn these forums are good!!!
    Many thanks again.
    Regards,
    Martin
  4. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    +227
