AV32R... how old
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by primeaniac, Mar 1, 2005.
Tags:
  1. primeaniac
    primeaniac
    Hi there I've just bought this lovely thing :), newcomer to on Tag.
    Is there anyone who can tell me how old my machine is?
    Serialnumber AVD-000643
    It's a low number I think! Did the early ones have problems?
    /Thomas (sweden) <--- :thumbsup:
  2. highlander_777
    highlander_777
    Apr 4, 2004
    216
    and I bought it in 1999, no problems :thumbsup:
  3. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    I have number 783 and it was a 2 processor version when the sharcs were less powerful than those that became standard fitment. Only problem this resulted in was when I wanted to do a DTS upgrade and it wasn't possible with that earlier 'non-standard' configuration. At the time, the factory solved my problem FOC when I sent the processor in for some other upgrade work (192 dacs I think).
  4. primeaniac
    primeaniac
    Thank you for the answears.
    Well It seems like this store have lied to me then, but it works just fine =).
    What kind of DTS upgrade are you talking about?
    Is their anyway to tell what/which processor/s I've got.
