AV32R-DP question
Discussion in 'TAG McLaren Audio Owners' Forum' started by alexs2, Mar 8, 2005.
  1. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Just a quick question for those that have one....I've just bought one of the HiFiBitz AV32R-192bp processors with the DP option.....does the DP option require the 7.1 upgrade also,or will it work with 5.1 processors as well....?
  2. lovegroova
    lovegroova
    Jul 15, 2002
    2,547
    103
    Herts
    +304
    As someone in the same boat as you, it will work 5.1. You just can't use the 7.1 modes like PLIIx, DTS-ES etc (rather obvious that!). TMREQ will work just fine.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Many thanks for the reply...just reassured me that yet more bargain rate expenditure wasnt going to be required!
  4. Inotrope
    Inotrope
    Dec 23, 2004
    680
    Nottingham
    +39
    May I ask a silly question; I'm a newbie to HC, and have ordered a DVD32FL and a AV32R-192bp DP as well as a 100x5R, I have a nice 2 channel system, but this'll be the first HC system I've had.
    The question is; do I need 7.1 upgrade? Does it add extra functionality (other than the extra 2 channels?); or should I stick with 5.1 until I have the space (& speakers) for a 7.1 system.
    I am concious than the upgrade will not be available for ever.... and that is equipment is at a good price, and ultimatly, 7.1 may increase both the longevity and re-sale value of the kit.
    Thoughts?
    mark
  5. DanielB
    DanielB
    May 27, 2004
    158
    Switzerland
    +12
    PLIIx does work as well in5.1 mode, only the display does not display PLIIx but PLII.
  6. Mr THX
    Mr THX
    Nov 26, 2002
    1,293
    Barnsley
    +31
    Do you know if they still have some of these ?? Are they on the web site??
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    As of right now,yes they do still have some going.
    Silver DP models only.
  8. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    The 7.1. model differs in that it has 7 outputs! the 7 channel surround modes can be used......... and it has the row of action trigger switches. That is about it.
  9. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Sevenoaks Cambridge have some AV32DP coming in shortly.
    I have ordered a black one with 7.1 option - the price is GBP2700 - this sound like a good do to me.
    As I didn't need the extra options on the AV192, and the rogues who now own TAG probably won't be bringing out an more options I thought this was the best route.
    Can't wait to get the advantage of TMREQ.
  10. Burgy100
    Burgy100
    Apr 20, 2004
    137
    Bedfordshire, England
    Check out the website at hifiBitz you can get it cheaper than that, but its only in silver
    www.hifibitz.com
